I installed new clutch plates and still have nothing starts right up but does nothing when I put it in any gear including reverse, same as before I replaced the plates drove just fine turned it off and went back about a hr later and it started right up but would not move. Reverse is not disengaged doesn't matter even in reverse
Is the chain on? Just kidding of course.
The warrior basket doesn't have much travel, if the plates are slightly worn it will slip, if left this way out will wear on the basket and pressure plate.
Am easy fix is an extra steel plate in the middle of the clutch pack. This acts like a shim giving you more clutch.
Make sure the fiber plate fingers have not worn grooves where the bump against the basket.
If all looks good and all the plates are installed throw an extra steel in there.
