does anyone with heim joints in their A-Arms have a rattling problem??? i just bought all new heims and it seems like there is some play in them. when you shake the front end it sounds loose. whats up with that??
Where are they lose?
What brand are they?
Did you get them from the a-arm mfg?
If its between the ball (the part that the spindle attaches thru etc) and liner or housing there may be some problem or issue with the fit of the pin that goes thru it or the internal clearences of the bushing in the joint itself.
If it is this point that is giving you trouble its odd cause most times it seems there too tight.
If its in the end where they thread into the arm then there should be a nut holding them, but some set ups work differently too.
Mine just squeek....
