1 - 20 of 30 Posts
· Registered
I've been seeing a lot of posts concering tire size and rim size.
Here's how to tell if a certain tire will fit on your rim
Here is what the "numbers" of the tire mean:
Height X Width X Rim Size
As long as the tire's last number which is the rim size is the same as the size rim your trying to install the tire on it will fit.
If the tires rim size is smaller or larger then the rim your trying to install the tire on it will not fit.
For Example:
I have a tire that is 20x11x9 will this fit my 9" rim?
Yes, it will fit your rim because the last number of the tire size 20x11x9 is the same as your rim size (9").
I have another tire that is 20x11x10 will this fit my 8" rim?
No, this tire will not fit your rim because the last number of the tire size 10 is not the same number as your rim size (8")
Hope this cleared up "What Tire will fit my rim" issue.
· Registered
I have a pair of rear 20x12x9 tires. Will these tires fit my stock raptor rims??
· Registered
ok thanks but does the width not matter?
· Registered
Quadracer89 said:
My size is 24x9x11, will tires that are 25x10x12 fit? I know it should match up with the last number, but will one # really make a dif?
they would not seal, the last number HAS to be the same no if ands or butts :tup:
· Registered
yea if the rim size is the same. It would look like shit, but none the less, it would fit.
· Registered
ok i want to get the new hole shot HD rear croos country tire
and the wheels i want are also designed for cross country and mxthe carbon fiber dual beadlocks
20x11-9 and 20x11-10 the tires
9x9 and 8x8 wheels
wtf
1 - 20 of 30 Posts
