1 - 13 of 13 Posts
My warrior seems to be slipping in all gears mainly 2nd through 6th when i really have the throttle open. But then if i ease it into the the gear its fine.. Is it the clutch/clutch plates going bad?
Yep. Time for some Primary Drive plates.
What are they actually called? What do i need to get? Can you send me a link? Is it hard to replace?
you didnt happen to put regular car oil in the last time you changed the oil did you?
NO!! lol i used the diesel rotella 15w20 or 40, I dont remember,and i put that in last Sunday... but before i put that in i used ATV oil 10w40. and that was my first oil change.. Ive only had the machine for about 2 months now.
Discussion Starter #9
I just read the discription of the driveline clutch and it seems they have it down to a science.. I'm going to get that set beastly.. How hard is it to replace the clutch?
I put a Drive Line clutch in a friends big bore stroked Honda 450. So far it is doing very well. Time will tell.
1 - 13 of 13 Posts
