I am leaking fuel where the needle sits into the jet, i have taken the jet, out and cleaned it, i have cleaned pretty much the entire carb. I am really depressed that i can't seem to fix it, ANY IDEAS
could it be the throttle cable needs to be tightened, the needle is bad,
everything is stock on carb except jets and needles, Got the gytr jet kit.
Also i just put the stage 1 cam in it, i figure i need bigger jets any ideas
:bk: :bk: :bk:
how do you know its leaking? are you sure its not something normal?
