1 - 20 of 21 Posts
Well today I went to walmart, just looking for stuff that icould use to clean my engine. Well I bought a bottle of CLR, went home and used it in a small spot with a tooth brush and was amazed it actually brings back the old engine color. My engine look like crap from mud and stuff and figured i would give it a try, and it worked. The bottle is only $4.75, and it makes your engine look good. I will post before and after pics after im done.
will it work on other parts of the machin like the frame and headpipe?
CLR is good suff. I dilute it down and use it on painted surfaces to get rid of water spots, just test it in an out of sight place to make sure the paint can handle it.
Watch out you don't breath in too much of the fumes, (it gives me a headache).
You could always try gunk. It worked really good on the motor of my old bronco that was coated in mud, it took a few cans because the 351 was a little bigger than a raptor motor though. Just be careful if you use it and live in California, it causes cancer there. Anywhere else you should be fine.
hey can you just spray engine degreaser over your engine without having to cover stuff up? iv wanted to do it but was afarid of it might do something to something lol. didnt want to mess up stuff. so how about it?
LMAO.... So does breathing the air... :lmao:
I have sprayed degreaser all over my engine and nothing has happened so far.... :shrug:
Be carefull with some cleaners. I found out the hard way using that purrple stuff (the name of it evades me right now) does very bad things to polished aluminum. :s96: :(
I know a lot of the car detailers use some pretty wicked stuff, and some of it will eat the hell out of almost any surface (particularly those nice Aluminum wheels) unless they are wetted first. That seems to be the key with everything I have tried. As long as it is wet first, then spray the stuff on, it wont eat anything up.
Always safe to test first though.
:lol:
whatever as long as i can still use it i dont really care what it could under certain circumstances do...
another thing you can use if you dont mind spending the money is S-100. You can get it at any Harley davidson dealership. It is expensive but it works real good at restoring the color of the motor.
1 - 20 of 21 Posts
