1 - 19 of 19 Posts
TopGunnYFZ450 said:
Foxracin said:
Ummmmmmm... NO cause the front sprocket will still be on the left. :lol:
Lol but what if you turn the engine around like that one banshee? Then youd need to figure out how to get it to run backwards!?!?!
Do you see and advantage to a right side drive?
If u turn it around wont the front sprocket be at the front of the bike tho :razz:
woa im so confused :wtf:
Im following, the sprocket on the engine would be towards the oil tank so you wouldnt be able to run it to the axle sprocket in normal configuration
Discussion Starter · #9 ·
Im looking as i mentioned before in another thread that i will be putting a R1 engine in my raptor.
On the 2000-2001 R1 the front sprocket on the engine is on the right side...does flipping the rear axel make sense now?
:nod: :nod: I can't even imagine an R1 motor in a Raptor! :scared:
MoRaptor02 said:
I get it. I was lost when you talked about turning the motor around. Good luck on that project.
meee toooo!! sounds like it will be sick, i cant see any problem with flipping the axle but then again ive never done it!
Are you sure about the R1 front sprocket being on the right side? Every R1 that I have ever seen since they started building them in 1998 has the drivetrain on the left side of the bike.
I agree, every R1 I've ever seen has the drivetrain on the left hand side. I even just did a search for pics of the 2000 and 2001 like you said and they are on the left like normal. There aren't many bikes out there with it on the right
Discussion Starter · #16 ·
I was looking at a complete R1 engine on ebay and found 2. One of them was a 2000 and the other a 2003. I compared both pics and I couldn't see the drive train on one of them so i figured its on the right side. :shrug: and the other that i could see was on the left.
I looked at both pics side by side from each engine to make sure that i was looking at the engine correctly for which end goes forward on the frame. One of the engines came with a radiator aswell and used that engine to determine which end goes forward.
Discussion Starter · #18 ·
1 - 19 of 19 Posts
