Just bought a wrecked 2005 Yamaha Big Bear 400. It has good spark and compression is good. I cannot get it to start. Cleaned the carb with no luck starting it. I removed the plug and put in a little gas then replaced the plug. Still nothing. Any ideas???
how bad was it wrecked? check for fuel in carb, what was the compression number? psi? easiest is try a new plug, cheap and easy to replace, may be fouled
I can't really tell how bad it is wrecked. The plastics on the left hand side are all messed up. Everything else is straight - nothing warped. There is a lot of dirt / mud under the gas tank.
Compression is about 120 psi. I've got a good spark with a new plug @0.6mm. Checked fire and its good.
Just checked the timing.
When the timing chain is set to the TDC mark, I cant see the timing mark on the plug on the rotor. It looks like its about 1/2" off.
Is this enough to cause it not to start???
Stator assy are subject to going bad with bad impact crashes, are you sure you have good spark, I mean, repeated spark,spark,spark, not just one spark when trying to start. Otherwise, start from scratch, like ranger said, with a new plug, try ether(quick starting fluid), not raw fuel in the carb ,that will foul it quick, fuel is supposed to be atomized(vapor) when reaches the cylinder. Good luck
spark fuel and compression still no spark?
I also have this problem on a 1987 yamaha moto 4 350. Spark seems to be very weak, but when i take spark plug and spark plug boot off the coil wire produces very good spark, replaced plug and boot still weak spark at plug???
