There is a reason they are cheap. They usually sound horrible.
it makes a power increase but check with your state laws, it's so loud you are not allowed to use them on public lands here
i already asked this ahaha but what size jets should i go with and what company jet kit should i go with such as hmf jet kit, or dynojet kit?
Well i will tell you what i had to do when i got my yoshimura pipe i got a jet kit and it didnt run right for 2 days of tuning i removed the jet kit and got rid of it and i just went to my local dealer and got a bigger main jet ( i got 4 jets starting above the stock and up) they run like a buck each or so but after i put the stock needle back in and tried each of the jets i finally found one that works and it runs great. but i hope you have better luck than i did with that kit.
i just got a full dg pipe for my warrior off ebay, and i was very surprised sounds better then expected and i could tell a little with power.
