I am having a problem with coolant leaking out of my crackcase cover in the area below where the water pump housing bolts onto the cover. On the bottom of my cracnkcase cover there is a small hole below the waterpump. It does not appear to be threaded. I checked the schematics on the Yamaha Website and can't find a plug or bolt to go into that hole.
Has anubody else had this problem??? Can somebody go check their YFZ and see if there is a rubber plug or something in their hole??? I would appreciate it.
This is a common problem. I just delt with it last week. There are a lot of threads on this. Read up on the sticky in this section and you will find the parts and instructions on how to do it yourself. Bob at Magnolia has the parts. Just give him a call :tup:
I noticed this on mine 2 weeks out of warranty and Yamaha not the dealer would fix it. I feel bent over and rode hard. after this obvious manufacturing or desighn problem youd think they would have had better customer service.
