I have a yamaha warrior 350 1987. And the clutch is really hard to pull down. What do you think might be the problem?
warriors have a notoriously hard clutch pull but check to make sure the lever is free, the cable is free and well lubed. if it has been sitting a while you may need to pull the clutch and clean it. if it is all good you can extend the clutch lever on the motor. you would need to weld a new piece to it to make it longer and easier to pull but i am guessing that is above your current skill level. there are also some after market clutch levers that may help. fyi it is ok to put all of your questions in one post. it saves me time not have to go to and follow several post for the same thing
