Hi, here pretty soon i'm needing to replace my chain & front/rear sprockets. What size of chain should i go with, looking for factory size, like a 520-104 or 106. And what # of teeth will i need on the front/rear sprockets. All replies are appreciated.
If you like the way your bike runs now go back with the same size sprokets, if you want more top speed go with a bigger front or smaller rear or if you want more torqe go with a smaller front or larger rear. You can figure out the gear ratios by dividing the rear by the front for example a 40 tooth rear divided by a 12 tooth front would be a 3.33 ratio. The higher the number the lower the gearing... :))
