It's the small cover that goes over the starter gears. For some odd reason I just cant get the cover to go flush with the main case. Top part of cover is flush but bottom half sticks out about a 1/8" inch. Any idea what is holding the cover up? I know it is not the gears because I tried putting the cover on with just the metal pegs that the gears go on and it still won't line up right. Only thing I can think of is somehow the starter was tweaked out of place and maybe I need to loosen it?
double check the pin that holds the gear, take the gear off and make sure its seating properly in the stator case and the cover.
Found out that the starter o-ring wasn't seated 100% into the outer engine case so the starter shaft and gear wasn't perfectly straight. Thanks for the help tho
