03shee said:
What is a "boost bottle" and what does it do exactly
The carburetor crossover equalizes the pressure between the two carburetors so no extensive tuning is needed, twin carbs is difficult to tune. However, when you put on a boost bottle, it creates a reservor when the carburetor SUCKS on initial opening of the air valve the first rush of air is LEAN without the boost bottle, and then after the air gets moving the mixture richens due to appropriate venturi effect.
With the boost bottle, a charge of air with appropriate gas mixture is STORED in the bottle, and is sucked out when you first open the throttle.
The boost bottle is not noticible if you hold the throttle open, but if you go WAHuuunWAHuunWAHuun a lot, it will definitely help you. also, DONT FORGET TO REJET, you got up one or twom main jets when you install a boost bottle, or you are loosing potential power.
MORE AIR, MORE JETS...
Boost bottle acts like a CAPACITOR in an electric circuit, You, know, like in arefrigerator, if they didnt have a boost capacitor, your motor would have to be twice the sixe to start... with the capacito/boost bottle any little motor can give a bigger initial kick...
Some riders don't notice the bottle cause they are always wide open, and the bottle doesn't help much, but those who are on the throttle and off a lot, notice a difference.
