Glad i could find a place to help.
Having a hard time figuring out what's wrong. Everything runs fine until I get to full throttle then it bogs down and wants to die until I pull the clutch and then it catches. Everything is stock except for a K&N air filter. Haven't had it long, and it didn't start doing it until I rebuilt the carberator. Not really sure where to start, is it too rich? To lean? Can't tell anything from the plug.
Thanks in advance for any help..............
probably lean, put one size bigger main jet in it
Thanks
I appreciate the help.
What size is the stock jet that comes on the warrior?
Where do I get a different size?
I know these are probably stupid questions but I'm still learning lol
Thanks again..........
You prolly broke something loose when you cleaned the carb. I'd go through it again and clean the emulsifier tube that's under the main jet. They can get clogged pretty easy. I say this cause you said it worked fine until you cleaned the carb. I wouldn't change jetting just yet.
Also if you replaced the main jet with one from a rebuild kit, you might need to put the old one back in. Sometimes them kits have bad sizing.
