Well my blaster locked up, tooked it apart and it screwed up my sleeve, busted my 240 piston into 1,000,000 pieces and everything....
:scared: That sucks, clean it out real good, make sure you get all of the filings out of the chamber. Spray a crapload of wd-40 down in there and monitor how much filings are coming out. Same things happened to mine. And no, WD-40 won't hurt anything, the worst you will do is foul a plug. GL :tup:
Well, mine didn't exactly blow into 1000 pieces, it just got a chunk ripped off of it. It surprisingly didn't need to be bored/honed because the piece went right out the exahust port. But all you need to do is clean er out real good, get it honed or bored whatever is needed, and replace your piston, rings, and all taht garbage. Then RIDE!
