I have a 200 blaster and whenever i start it it revs reallyyyy high unless i pull the choke. it runs really good when on the choke but when it’s pushed in it sounds like it’s gonna blow. i put a new carb and reeds in it but it’s still doing the same thing and i have no clue what to do. suggestions?
you most likely have a vacuum leak somewhere. also check the throttle cable routing. look in the carb at the slide is it all the way down with just a small gap
