My 2003 yamaha blaster won't stay idleing I have to put it in gear before it revs too high somtimes I can get it to when I pull the choke out but only on a cold start please help
Does it start at an idle then rev all the way up to redline? Or does it have a stopping point. If it has a stopping point where is it? Would be around 1/4 throttle? 1/2 throttle ECT.
Did you try adjusting the idle screw? Try spray down the carb boots with starting fluid if you can. It that makes it jump in rpm then you have a vacuum leak and you need to replace the boot because there is a crack
Sent from my XT1585 using Tapatalk
