1 - 9 of 9 Posts
Bike Bogging/Stuttering 3/4 - Full Throttle [SOLVED]
Ok so i have a 2004 Raptor 660 with 102mm bore, +4 stroker crank, Yoshimura Exhaust, K&N filter (air box stock).
Jets #25 Pilot 180/185 Main jets.
It starts and Idles PERFECT. Couldn't ask for any better however,
I had a friend jet it for me at first and when i took it out it would run perfect from idle to 1/2 - 3/4 throttle, then it will bog out.
I took apart the carbs (because it was flooding, which a simple cleaning fixed) and i noticed he installed the jets wrong 185/180 (instead of 180/185).
So i switched them. Now it will Bog out AND stutter.
What can i do? Whats going on?
Edit: **PROBLEM SOLVED**
I removed the snorkel and airbox lid, and that's it. Rides like a champ!
Probably too rich try 175 180 and see how it runs
Could it be air related? I have the snorkel still attached.
I tried removing the air box lid. And at idle when I would blip the throttle it would bog. I have a #25 pilot and read to remove the lid you need minimum #27.5.
I'm at sea level
If you have a stock airbox you will need an adapter as the lid holds the filter in.
1 - 9 of 9 Posts
