you have 2 have a machine shop install it if its just a sleeve kit then you have 2 have a porter match up the ports and set your port timing. if you get a setup with cylinders its just simply bolt on but if your completely stock i'd pipe filter and the basics before you go big boring even then id just get porting. its not really the size of the bore its the port work. :nod: hope that helps you out
