1 - 8 of 8 Posts
I ordered rear and Front HiPer rims, 8" rears and 10x5 fronts and I want to get some Kenda Klaw MX tires. I am havent bought tires before and I was wondering what are the most common MX sizes(front and back) that will fit these rims.
Thanks
20" in the front 18" in the rear is what all the ppl that race mx use around here...
Well I guess I was wondering about the other dimensions. If the rear rims are 8x8 and I want 18" tall tires and my options are:
18X10X9
18X11X9
18X10X8
18X11X8, What are the tires that will fit my rim the best, Does the beadlock system play any factor either? I am guessing I would want the 18x10x8??
Thanks
18x10x8... and if the last number is 9 it wont fit because its for a 9" wheel...
YFZ450fanatic said:
What do you guys torque your bolts to? do you use loctite?
Thanks
torque them 8-10ft-lbs......... i dnt use loctite
1 - 8 of 8 Posts
