1 - 1 of 1 Posts
On my 2001, I had some clunking on the front during the last ride, so I pulled off the front wheel to check things out. I found:
The bearings on the hub have a very, very small amount of play. About 1 mm or less. Is this normal or is it time to change? If so, do I need a press?
Also, the upper A-arm mount to the frame has more play. Is that normal or do I have to replace bushings or bearings up there?
Thanks,
Tom
1 - 1 of 1 Posts
