I got the banshee out today and gave it a test run. started up great but when i put it in gear and started going it started bigging a little bit and it did this in every gear until i hit high rpm's. Any ideas what this could be?
Did you do the standard diagnostics ? Leak down test, plug chop to check jetting, compression test? Make sure the inside of your carbs are clean along with your air filter. Install fresh plugs.
How did the air temp compare to the usual temps you ride in?
