I was riding with a guy on an '04 'shee the other day and got to looking at his rear axle and bearing carrier setup. The width of the bolt tubes that the carrier bolts pass through looks narrower than those on my Blaster, but I couldn't really tell about the bolt spacing from top to bottom between the bolts. Is that spacing the same? I was thinking a guy could take up the narrower width with spacers on each side, but the spacing between the two mounting bolts would have to be the same. I've been thinking about doing a 'shee axle and rear hydros as a project this winter, and thought this would be a slick and easy way to do both, by just changing the whole bearing carrier-axle-disc-caliper setup. Any thoughts?
Sweet, I love it when a plan comes together. Getting it parallel, no trick there. Consider it done. eBay, here I come! Thanks!
