need some info on where to get or what kind of ball joints are used for aftermarket a-arms.(on the spindles i mean)
plus.......is the taper on the upper side same as lower side on the spindle?
thanks,
mark
You need to know hether you are runnuing a 14 or 16mm balljoint. The tapers are the same top and bottom. You can get them from just about anyone who makes aftermarket arms; Laeger, LSR, Burgard, Houser and on and on. Ricky Stator sells decent ones and Laeger has a real good set but they have a locking system on the bottom ones ( a notch that fits into a slot in the lower arm) so make sure you specify whether you need the locking ones as well. You can get the honda style without the taper but that would require reaming the spindles.
