Ok..first off i know you guys aren't going to like me, but i purchased a 2+2 Dura-blue axle for my raptor. I did not install it myself and had my buddy at the shop do it.. My question is this, i had put a a couple of hrs on my new axle and now it has some back and forth play in it. I can feel it when i put it up on a stand and pull on the axle...What should i do to fix this and what could be the cause? I replace axle due to bending the factor on an OAK..hahaha...Thanks guys you help me out alot... :tup:
Or just check and re-tighten your axle lock nuts..
:tup: :tup: or like Blastermaster58 bearings
blastermaster is right, its the bearings. ive had to do them on my bros warrior like 3 times
01's are know for the axle nuts coming loose, check that first. the axle nuts are the components taht hold the axle into the bearings.. And you guys are right if that doesn't appear to be the problem then put a set of bearings in it....
