So my warrior had broken exhaust studs so I took the head off and did the exhaust studs and it's 1994 through 1996ish warrior 350 and I put it all back together and I made sure that valve lash is correct and timing is correct and it's acting like it wants to fire over but then stops and so I just decided to get a top end kit for it so all the gaskets and piston ,rings jug,stuff like that but it said compatible with yamaha wolverine 350 and I was wondering if someone could tell me if the wolverine and the warrior have the same motors
Top end , cylinder , head , stator, magnéto, the casing
If the wolverine is a 350
It's mostly the transmission components thats
Different, if I presume I could be wrong,
I've stuck a wolverine 350 top head cylinder on my 91 warrior few years back still running with it
2003 Raptor 660, .05 over bore, FMF slip on, Fullflight +2 A Arms
I agree with what Alex777Yamaha says. Wolverine is a clutchless manual, and a Warrior is an actual manual, so the entire top end is the same. Good luck with your machine, Kayden.
