You could just run a wire from the battery to the light with a switch in there. That would be the easiest way, and I don't think it will drain the battery, as long as you don't leave it on.
Its low amperage battery cant accomodate lights. Ignition alone uses too much. LED lights would be appropriate. Or a headlamp lolYou could just run a wire from the battery to the light with a switch in there. That would be the easiest way, and I don't think it will drain the battery, as long as you don't leave it on.
