Hi I'm new to owning a blaster first of all. I bought this machine used and without riding it first. When I got home and went to rip around on it, I noticed the rear jumping. I stopped and jacked it up and found the rear bearing carrier was busted and only had 3 bolts holding it to the swing arm. I'm trying to buy a new carrier and everyone I look at doesn't look like the one on mine. Mine is a solid cast with four ears where it bolts to the swing arm, and everything I've found has 2 ears with a rod like running from side to side. Is the one I have even for this quad. I did run the vin just to make sure it came up as a 97. Somebody please help.
Stock pre-2003 carrier apart:
Assembled. Ignore the brake. It is a Ninja 250 rear brake on a modified mount:
