We were out riding and I revved it up a few times and dumped the clutch. It made a loud clacking noise and died. After that it wouldn't start unless pull started. Once pull started, I pulled the clutch in and it sounds like something being knocked around in the lower end... Its the same noise in neutral and in gear. The magneto is in tact. Need to know where to go from here and what it could be. :help:
well we found what may be the problem and why it sounded like something was being thrown around...gear in the oil pump..so would he need to buy the whole oil pump? And is this most likely what is causing the whole problem
