I have a 95 warrior that dies instantly when I put in reverse...like I cut the key off....is their a easy cheap bypass/override I can do to fix this....not concerned with the light coming on...thanks in advance
ground the green wire that hooks to the brass switch on the shifter. you light should still work i think but its been a while
Worked perfect!!! Grounded it to neg side of battery and reverse is perfect and still have light also....thanks again!
