Howdy. I have a 1990 Yamaha Warrior that I acquired a few weeks ago. The previous owner is a good friend whom I know took good care of the machine. Every so often, when I try to shift out of neutral into first, it grinds across the gears. In order to get it into gear, I have to shut the quad off, and as it shuts off, it falls into gear. any help is helpful
clutch is either warn or out of adjustment if it is always. if it only happens when it cold or first started it is normal exercising the clutch and warming up the machine will help warm up the plates
