1 - 9 of 9 Posts
I have a green wire with i white stripe on my 87” warrior.. it runs all the way from the front of the bike to the back but it splits off somewhere around the spark plug but is cut and I don’t know where it’s suppose to go. Does anyone know please tell me. Thanks
you are going to have to get a diagram to find out for sure my guess is a safety switch that has been bypassed. if the machine run just tape it off and call it a day
Ok well I am definitely having a problem with it running but I’m pretty sure it’s in the electrical. Where do I get a wiring diagram? I’ve been lookin all I can find is 88” and up
There is no green/white wire on a 87. That started with 88, it is the reverse rev limiter wire and goes to the F - R lever switch. You should have 2XK-20 on the CDI. 87 had a 1UY-20 CDI.
Hey tom baur my 98 warrior will not start the green/white wire is not connected down by the the reverse. Is that the ground and does it have to be connected to the reverse lever for the quad to start? A pic would be great if that is possible. Thank you in advance!
tom baur i was wondering i have a 98 warrior and the green/white wire down by the reverse lever is not connected anywhere could this be why it will not start? And if so where does the wire connect to? Thank you in advance!
Thank you. You seam to know your stuff. I just bought it hope if I have any other questions I can reach out to you. Again thank you
1 - 9 of 9 Posts
