The bike starts good with the choke and idles without choke after warm up but when I try to open throttle it dies, sometimes runs a little if I pump the throttle.
I checked the compression it seems low at 100 psi. I put a new carb on and the fuel flows well through the petcock and filter. I had the engine running and sprayed gum out trying to find air leak and got nothing.
Got any ideas?
thanks Gary
It's the 225. Not sure how many miles on it . It looked well used when I got it 22 years ago. I don't use it a lot.
I adjusted the needle and I runs better still finicky at transition to high RPMs. Starts on choke and idles after warm up.Still backfires sometimes. Was thinking about rings and clean up valves and head.
