Every time I pull in my clutch it dies and when I give it gas it Boggs down and will not start unless I pull start it I messed with the Idol and changed out the carb on it and it’s still doing the same thing
did you change one carb or 2. did you rejet the new carbs, you cant just slap on a carb. is the fuel old. did you do a compression check? did you adjust the valves? are the carb boots good and the carbs properly placed in them? did you replace the spark plug
