I've only had my quad for a short while, had it out 5 or 6 times. been to 2 OXCR races. Yesterdays race, the temp light came on before half way around the first lap. took it easy on it and tried to get air flow, while watching if the light would go out. I went another lap, before stopping at the truck to try and see if I could fix it. didn't see any blown fuses, have never seen any puddles under it from leaks or signs of leaks. when I stopped, the fan was not on. I will have to get my test light and stuff from work on Monday before I can check the fan out.
Any thoughts on what I should check first, figure I'll use the power probe to see if the fan will spin with good power and ground. If that doesn't do it, not sure where to find a wiring diagram to figure it out.
