i have a 2005 raptor 350....i have 4 months with it i already changed the oil 4 times.....motor is leaking oil from different places....not alot but just enough where you can see oil......are the gaskets bad will the dealer fix free of charge.....what could it be.......??????
Well where exactly is it leaking from is the real question, some places like around the oil dipstick naturally leak a little bit, and around youre oil drain plug if its not tight enough it could leak. :wtf:
is there oil between the head and case gasket , i seen some leaking there from blown head gaskets . better get it to the dealer before the 6 mo. is up .
my friend had this problem on his ex, just needed new gaskets
