hey guys i am new to the blasters i had it out for a ride and it stalled on me. it is all stock and now as far as i can tell it has spark. i loosen the screw on the carb float and fuel runs out so fuel is getting to the carb. but when i remove the plug it looks dry so i assume no fuel is getting to the engine. any ideas. i am not sure how these engines work so any help would be great. thanks.
i am having the same problem with my 89 blaster, i am getting spark, and air, and fuel but she wont start, i cleaned the carb, and checked the reeds.:???: people help us
If you have piss poor compression ie: you can rotate the kick start with one finger I would reckon to say its time for a top end job. You can pour a little engine oil in your plug hole put your plug back in and see if it gives you more resistance turning it over if it does usually means bad rings. Also check for leaking/blown head gaskets. course check your reeds too possible you lost a petal and sucked it in messing up your rings.
