Bought a 02 warrior and can only get it to start by turning key off and jumping the solenoid. It will not get spark when key is turned on. Bought a new key switch and same problem. The red,brown, and black wires all match up and then there is a black/white wire on the key switch going to a black/red wire on the wire harness. I know the black/red wire is what gives the spark but can’t figure what could be wired wrong for it not to get spark with the key on. Any ideas?
it is probably the key switch it is very common to have the aftermarket switches wired incorrectly inside the switch
It is not a 2002! Get a new genuine Yamaha switch for a 87 and your problem will be solved. Likely it is a 1987 bike.
