What's up guys haven't know to the group I don't know what's going on with my raptor been having lots of problems with my electrical I bought a wiring harness for a thought to believe 01 raptors 660 got it all hooked up and realize I didn't have the green and yellow wire connector for the CDI So I did some research and found out that you don't need that? Green and Yellow wire is this true or not I am told that it is the reverse switch? I've been pulling my hair out with this and my wife's warrior also has a no spark issue I've checked everything with the multimeter from a ignition coil to stater I replace stater On my wife's warrior as well And voltage regulator I did the same thing on the raptor But can this be done with this 2001 raptors 660 and delete the green and yellow wire I should Probably I've asked this in 2 separate questions
That's a difficult one, have to compare worrying schematics in the manual. Best idea is to match wiring to the engine
