Hello everyone. My warrior runs great but doesn't charge.. I'm getting 12.30 volts with it running and lights on.. The white wires on the stator check out at 0.8 ohms. Is there anything else I can check to see why it's not charging.. Whoever put this stator in didn't put the grommet in right so it leaks because it's just floating around in the outer part where the wires come out...so I need to take that cover off anyhow. I'm thinking maybe it's the voltage regulator.. What do you guys think and how do I test the regulator..
Thank you for your time and your help
-John
check the voltage with the bike off and then start it and note the difference. then check it with the revs up a little and note that voltage. I am away fro my manual today and cant look up the specs for you but I will check tomorrow there is a test for the rectifier but they don't fail often it is normally the stator. I cant remember off the top of my head but that number does not sound correct.
