i have a 97 warrior just bought and its hiting the limiter someone removed the parking break and wires so i can fine the connector to see if it was done correctly the clutch sensor was removed and pluged into each other so thats good but i can figure out why its in rev limiter so much what controls it? does it do throught the cdi box
i have 3 other warriors but they r different years
does any one have a diagram for 1997 warrior i need to trace the wires to find them
if you have that many warriors just order the clymer manual it has great color diagrams for all warriors. best 30 bucks you can spend. as far a the parking brake all you have to do is unplug it so it would be unlikely that someone could mess that up. try grounding the green wire that goes to the reverse shifter.
there should be a brass switch like the neutral safety switch by the reverse lever with a green wire going to it. put an circle or u type end on it and secure it under the bolt that holds the shift bracket to the frame
