Hi i am new to this forum and was wondering about an idle problem on my carb. While it is still warming up the engine idle is perfectly normal but as it gets warmer the carbs butterfly valve just kind of sticks all the way open and basically runs full throttle. Does anyone else have this issue and have you fixed it. Thank you it is a mikuni carb
Are you positive it's the carb and not the cable?
Pull it apart, and check the slide on it if so. They do get worn out from a ton of use.
