I recently bought a 1990 Yamaha Big Bear 4x4 350 for a good price, But it needs it's share of work. A few problems I have ran into.
I cleaned the carb, and lubed the cables.. But for some reason the ATV wants to idle high, I've cleaned all the jets, (Didn't take any out) and I've backed all the cables all the way down as far as they will do. It idles way to high, Causing me to grind gears.
Another thing, I don't know if this is a 4 wheel drive or full-time 4 wheel drive. It only has H - L - R on the lever, and the 5 speed shift lever. Which is it? It looks like there are a few cables missing? Where can I get a whole new shift assembly and cables?
Also, It may be because it idles to high but it has trouble shifting. It's really really hard to up shift / down shit (I have to keep fiddling with the shifter to get it to downshift / upshift) I know it's an auto clutch. Is there any sort of adjustment I can make to fix that? It did sit outside for 5 years, I don't know where water did / didn't get into. Can I inspect the clutch without tearing the whole engine down? How hard are they to replace?
Thankfully I managed to find a Hanyes manual for it, But it won't be here for a few weeks.
