i have seen the shifter weld itself in place with rust but if the shifter is moving and the shaft going into the case is moving and it is still stuck you will have to split the cases
if i do that im taking it out no reverse will that hurt anything?
i would have to look in the manual but i dont think its possible. the gears are on a shaft and you would have to at least make a spacer to replace the gear. you might as well just use the gear
