09 450yfz. What causes the coil pack to fire once then quit. If you cut the switch off then back on itll will fire again then quit. As long as you keep cutting switch on and off it will fire once then it quits. Can anyone help me out with what would be causing it to quit firing like that. Thanks in advance
