1 - 1 of 1 Posts
so i have a 06 raptor.
replaced parts: starter - one way bearing - starter coil - starter relay - neutral relay - battery - spark plug - push to start/headlight handlebar assembly - stator
after replacing all of those parts i fixed a few problems i was having and got it to crank - i have spark and full gas (i checked to see if the gas was flowing when valve was on)
when the push to start button is pressed it sounds like it is trying to start but it never does iv made sure all connections are good with all the wires im at a loss here
i have no clue what else i should be checking iv ordered another stator thinking maybe the last one i bought was bad so when it comes in ill swap them out
1 - 1 of 1 Posts
