1 - 8 of 8 Posts
04, 660 Raptor wont start or turn over. I was driving it fine, stopped for 2-3 minutes to get directions out of a bag. Went to start it back up and absolutely nothing. N light comes on, but nothing else. Battery is fine and lights come on strong if I try them. No clicking sounds, nothing. Tried having it push started and it wont start. Tried having it pulled while I had it in a higher gear and popping clutch and nothing. As long as wheels were moving and clutch was in, it kind of sounded like it wanted to. Thanks in advance.
sounds like you're going to have to break out the meter and go over the electrical system. seems like I just read something about wiring to the cdi rubbing on the frame and wearing through being a common issue....
www raptor forum com/forums/66-raptor-660-maintenance/60922-most-common-raptor-660-problems-explained-read-before-posting-your-problems-8.html#post1094849
Sounds like a safety switch, clutch or reverse lockout.
I had that happen to me. I started by going over the whole thing with a meter checking power. Later found out I just blew my 30 fuse.
I just replaced both fuses to be safe and it started right back up. Simple problem. Happened by my key housing tough my metal plastics bracket. Made a little spark and blew the fuse.
Sent from my iPad using Tapatalk
1 - 8 of 8 Posts
