New to the forum. Been doing a lot of reading but havent came across a problem exactly like mine. I recently bought a 2004 Raptor 660 it was sitting for a long time A lot of it was a part put it all back together. The battery held a charge. put new starter solenoid on, patched up a few wires cleaned out the carburetors, headlights work brake lights work all the lights, neutral, reverse lights all come on when I push starter button but nothing happens when I cross it at the solenoid it starts right up but will not shut off with kill switch must turn fuel off and run out of gas or pop the clutch to turn it off I checked the starter switch on the left side handlebars it's all clean almost looks brand new I am not sure if my solenoid is exactly wired correctly I will attach a picture of how it was when I got it I recently bought a new solenoid and cleaned up positive and negative battery terminals and put new solenoid on the way it was when I received it someone you please help me thank you. This is how it was wired up so with a new solenoid I wired it the same way, is this correct in the picture or no? Please help asap
that is not factory for sure. should only be the 2 small wires. you will need a wiring diagram to figure it out. i suggest the clymer manual. it has great trouble shooting and wiring diagrams
