Did you loosen the big bolts on the side of the swing arm housing before adjusting it? You may have stripped out the tighteners
Sent from my iPad using Tapatalk
If you followed the proper adjusting procedure and have the adjuster screws all the way in you will have to take a link out of the chain. It has stretched. Be careful if it stretches too much it will break and can cause damage to the engine cases.
